app Netflix error on Medion X16515
3 ANTWORTEN 3
ljenny
Nachricht 1 von 4
4.646 Aufrufe
Nachricht 1 von 4
4.646 Aufrufe
Hi. We have a problem on our Medion 65". The app Netflix does not work anymore. There is shown this error: Code UI-800-3. Any info about that?
3 ANTWORTEN 3
Iks-Jott
Nachricht 2 von 4
4.640 Aufrufe
Nachricht 2 von 4
4.640 Aufrufe
Hello @ljenny
Welcome to the community.
I didn´t have that TV. But did you ask Goggle?
By example https://www.google.com/search?q=error%3A+Code+UI-800-3&ie=utf-8&oe=utf-8&client=firefox-b
Kind regards!
Iks-Jott
ljenny
Nachricht 3 von 4
4.631 Aufrufe
Nachricht 3 von 4
4.631 Aufrufe
Hi! Yes I checked on Google and I just found to re install the app (I don't know this procedure), or close the tv for a while, close internet connection and reconnect it... These solutions did not work but... I cheched again on my tv and I try among the options of the app... the"Reset". After reset the app worked again :). Thanks for your support.
Iks-Jott
Nachricht 4 von 4
4.629 Aufrufe
Nachricht 4 von 4
4.629 Aufrufe
@ljenny  schrieb:
Hi! Yes I checked on Google and I just found to re install the app ...
@ljenny
Well done! Smiley (überglücklich)
Regards
3 ANTWORTEN 3
