on 19.11.2018 07:36
on 19.11.2018 07:36
HI All,
Brought 4 units and having a few different issues.
1. Number one linked with the Life+ software and can be controlled from the software. When I try and link to Google home using "works with Google" it recognise my password and I press Authorise.
It then goes to a white screen saying accounts now linked. https://assistabt.google.com/service page. But nothing happens!
2. Number two and 3 - Power button wont turn on (straight back to the shop)
3. Number 4 - These wont sync with the controll software Life plus. Blue light flashes then when I get top about 7% the light stops flashing and goes out, then at 100% I get an error addition failed please add again or view the help. I waited for about 30 seconds before proceeding to start the pairing, this at least went past 7%. light went solid, but same error at the end. . no success.
The ability to get that blue light to flash is also paiful. More luck than skill.
Any thoughts?
on 17.04.2019 11:27
on 17.04.2019 11:27
Thread closed due to inactivity.
