Aldi Ambiano microwave
3 ANTWOORDEN 3
Goneill75
Bericht 1 van 4
5.008 Weergaven
Bericht 1 van 4
5.008 Weergaven
Hi I purchased an Aldi ambiano microwave oven a year ago and it is running at 00.00 minutes when switched on at the wall and won’t stop running until switched off at wall.
when running at 00.00 it is not heating food. Can you confirm this is a known fault. I have a 3 year warranty. Please let me know what to do next. Gareth
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Gehringer
Retired
Bericht 4 van 4
4.988 Weergaven
Bericht 4 van 4
4.988 Weergaven
Hi @Goneill75 ,
you can call Medion technical support lines.
The contact numbers can be found at your country's Medion webpage.
Regards,
Gehringer
3 ANTWOORDEN 3
Gehringer
Retired
Bericht 2 van 4
4.998 Weergaven
Bericht 2 van 4
4.998 Weergaven
Hi @Goneill75  and welcome to the forum!
Have you tried checking on the user guide how to configure the time (clock)?
It looks like that you need to set it first
Regards,
Gehringer
Goneill75
Bericht 3 van 4
4.991 Weergaven
Bericht 3 van 4
4.991 Weergaven
Yes I can use the microwave and it did work. It has now stopped working. As mentioned it will not switch off and move round when clock states 00.00
seems to be a mechanic fault. Where do I send it to for replacement?
Gehringer
Retired
Bericht 4 van 4
4.989 Weergaven
Bericht 4 van 4
4.989 Weergaven
Hi @Goneill75 ,
Regards,
Gehringer
3 ANTWOORDEN 3
