18.12.2022 19:30
18.12.2022 19:30
Hi, I bought a Medion tower from Aldi a couple of years ago and am now looking to upgrade from the inbuilt chip to a graphics card. The problem is, I cant find any info on what cards are compatible with my motherboard. The pc is a Medion i5 8gb 1tb SSD desktop (this is what Aldi labelled it as), the board is a B460H6-EM. The MD number is MD 34435, and I believe the MSN is 10023875 (the sticker has somewhat faded).
Any help would be greatly appreciated
Wongus
18.12.2022 20:43
18.12.2022 20:43
Hello @wongus and welcome
an ECS B460H6-EM motherboard has a normal PCIe X16 slot.
You have to be careful with your power supply unit, which only has 250 watts and might not have enough power.
depending on how power-hungry your new card is.
bye Fishtown
18.12.2022 20:43
18.12.2022 20:43
bye Fishtown
18.12.2022 21:04
11.04.2023 20:14
23.04.2023 00:15
23.04.2023 00:15
Did it fit i need to know because i want to order the same gpu?
23.04.2023 00:29
23.04.2023 00:29
Yes its fits and it works amazing. But the sata cabbles can be a bit tedious at first. But it will definitely work
23.04.2023 00:33
23.04.2023 00:33
what medion pc do you have? and do you have the motherboard B460H6-EM?
23.04.2023 00:50
23.04.2023 00:50
I have a nzxt flow 5 in black. That medion B460H6-EM motherboard. A intel core i5 10th gen (dont know the specific one). 8 gb of ram (idk what brand). A 650 watt psu. 1 TB toshiba HDD. A 256 GB SSD and a rtx 3060 tuf gaming gpu. I first had a total prebuild (dont know what prebuilt) but i bought the new case to fit in the gpu.
23.04.2023 01:05
29.05.2023 22:34
29.05.2023 22:34
I run that same motherboard with the ASUS Phoenix NVIDIA GeForce RTX 3060 V2 and it works fine. But this is a single fan card so it is shorter.
UserBenchmarks: Game 93%, Desk 90%, Work 84%
CPU: Intel Core i5-10400F - 87.8%
GPU: Nvidia RTX 3060 - 103.2%
SSD: S11-512G-PHISON-SSD-B27 512GB - 86.3%
SSD: WDC WDS100T2B0A-00SM50 1TB - 97.3%
RAM: Samsung M378A1K43CB2-CTD 2x8GB - 82.7%
MBD: Medion MD35068
