md35273 BIOS update B660H7-M20 motherboard
30 REPLIES 30
andr3y
Message 1 of 31
Message 1 of 31
Hi guys. I've got a md35273 (MSN 10024677) with MB B660H7-M20 and B660H7W0X.107 BIOS. Tried to update it to 2.12. Downloaded the BIOS from the link on this page https://community.medion.com/t5/FAQs/How-do-I-optimize-the-stability-of-my-desktop-PC-with-an-Intel/... and followed the installation instructions. After running the CMD as Admin and entering the command "UpdateBIOS.bat" all I have is this
Spoiler
C:\Users\andr3\Downloads\Bios112>UpdateBIOS.bat
C:\Users\andr3\Downloads\Bios112>if exist 123.txt del 123.txt
C:\Users\andr3\Downloads\Bios112>if exist log.txt del log.txt
C:\Users\andr3\Downloads\Bios112>if exist pass.txt del pass.txt
C:\Users\andr3\Downloads\Bios112>if exist fail.txt del fail.txt
C:\Users\andr3\Downloads\Bios112>REM SCEWIN_64.exe /o /ms "Enable VMD controller" /lang en-US /logfile: 1.txt
C:\Users\andr3\Downloads\Bios112>SCEWIN_64.exe /o /s log.txt
| AMISCE Utility. Ver 5.05.08.0009 |
| Copyright (c) 2023 AMI. All rights reserved. |
WARNING: Duplicate questions found. Only one question will be enabled in the script.
Script file exported successfully.
C:\Users\andr3\Downloads\Bios112>SPG0ECString.exe log.txt "Enable VMD controller"
????????? 123.txt
C:\Users\andr3\Downloads\Bios112>if not exist log.txt goto Double
C:\Users\andr3\Downloads\Bios112>findstr /c:"Options =*[00]Disabled" 123.txt
C:\Users\andr3\Downloads\Bios112>if 1 == 0 goto Pass
C:\Users\andr3\Downloads\Bios112>if 1 == 1 goto Fail
C:\Users\andr3\Downloads\Bios112>AFUWINx64.EXE B660H7W0X.cap /p /b /n /q /capsule
| AMI Firmware Update Utility v5.16.03.0120 |
| Copyright (c) 1985-2024, American Megatrends International LLC. |
| All rights reserved. Subject to AMI licensing agreement. |
C:\Users\andr3\Downloads\Bios112>goto end
And the update doesn't start.
Any ideas how to solve the problem? BTW checked the VMD controller option in BIOS before flashing - it's ON. If I turn it off, the system doesn't boot (BSOD)
Thanks in advance
30 REPLIES 30
andr3y
Message 21 of 31
Message 21 of 31
Hi @Major_ToM last time I tried the 1.12 from your post above, via install menu of B660H7W0X.inf file
Vince
Message 22 of 31
Message 22 of 31
andr3y
Message 23 of 31
Message 23 of 31
Hello @Vince thanks for help, that worked for me! The system BIOS succesfully updated to 1.12 😊
tokareev_
Message 24 of 31
Message 24 of 31
Hi guys !
I recently bought an i7-13700F for update my setup, however, my bios version is "American Megatrends International, LLC. B660H7W0X.107, 23/02/2022".
It doesnt seems to be compatible with my new CPU... I also tried to update to the Version 2.12, but as @andr3y it doesnt work... Where can i find the Version 1.12 and is it compatible with my new CPU ?
Thanks for help !
Message 25 of 31
Message 25 of 31
@tokareev_
Hi, the Link for  Bios 1.12 you find in post 22 from Vince:
--> https://cdn.medion.com/downloads/software/00_Bios_b660h7-m20.zip
Check here your MSN number first, if V. 112 applies for your  PC
--> https://community.medion.com/t5/FAQs/How-do-I-optimize-the-stability-of-my-desktop-PC-with-an-Intel/...
SuccessPC
tokareev_
Message 26 of 31
Message 26 of 31
Hi,
Well i did the update for 1.12 successfully then installed my i7-13700F, but now my pc isnt working anymore instead when i put my i5 back. Then no, the 1.12 isnt compatible.
Message 27 of 31
Message 27 of 31
@tokareev_
Well there is no other at the moment.
Please name your MSN number.  And  state the complete specs   of the  new  I7.
But you can ask. @Major_ToM .. May be he has some newer Bios, or does know
when a new release will come, taking better care of the intel 13th and 14 Generation.
cheers, daddle
tokareev_
Message 28 of 31
Message 28 of 31
Where can i find my msn number.
Maybe there ?  (The capture was before the update to 1.12)  -
Message 29 of 31
Message 30 of 31
Message 30 of 31
@tokareev_
Now I can see your picture, it wasn't authorisized before .
The MSN number you foínd in the first line of your screenshot.  --> 10024688
30 REPLIES 30
