16.09.2020 15:41
16.09.2020 15:41
Hello!
I'm trying to determine what would be a good replacement for a defective graphics card in a Akoya P5337H desktop PC. Getting a new version of the original card (GeForce GTX 760) isn't an option, so I'm looking for a good alternative that's compatible with this PC. I'm having a hard time figuring out specs, so any advice would be much appreciated.
17.09.2020 12:40
17.09.2020 12:40
Hello again,
Though I couldn't find information for the exact make of the MB you mentioned, all specs and requirements check out with regard to the 1650 for every version of the H81H3 I could find. Seems a safe enough bet so I've gone ahead and ordered. Returning the card won't be an issue if it somehow won't work.
Thanks for the info.
17.09.2020 10:11
17.09.2020 10:38
17.09.2020 10:38
Thanks for the reply!.
The MSN number is 10020310
Since posting my question, I've come across a very good deal for a GeForce GTX 1650. If this card would work in the PC, confirmation of that would be all the answer I need at this point. If not, the original question remains.
Best wishes,
C.
17.09.2020 11:04
17.09.2020 11:04
Hi @CeeKay71 ,
I would advise you to contact the graphic card manufacturer and check if it is compatible with your MB (ECS H81H3-EM2 SPO S1150 W8 V2#).
An alternative would be for you to buy it from a seller that would accept a refund/return in case it does not work.
Regards,
Gehringer
17.09.2020 12:40
17.09.2020 12:40
Hello again,
