New graphics card for Akoya P5337H
4 ANTWOORDEN 4
CeeKay71
Bericht 1 van 5
3.447 Weergaven
Bericht 1 van 5
3.447 Weergaven
Hello!
I'm trying to determine what would be a good replacement for a defective graphics card in a Akoya P5337H desktop PC. Getting a new version of the original card (GeForce GTX 760) isn't an option, so I'm looking for a good alternative that's compatible with this PC. I'm having a hard time figuring out specs, so any advice would be much appreciated.
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
CeeKay71
Bericht 5 van 5
3.424 Weergaven
Bericht 5 van 5
3.424 Weergaven
Hello again,
Though I couldn't find information for the exact make of the MB you mentioned, all specs and requirements check out with regard to the 1650 for every version of the H81H3 I could find. Seems a safe enough bet so I've gone ahead and ordered. Returning the card won't be an issue if it somehow won't work.
Thanks for the info.
4 ANTWOORDEN 4
Gehringer
Retired
Bericht 2 van 5
3.444 Weergaven
Bericht 2 van 5
3.444 Weergaven
Hi @CeeKay71 and welcome to the forum!
Can you please provide the MSN number of your product?
It is printed on a label underneath it
Regards,
gehringer
CeeKay71
Bericht 3 van 5
3.440 Weergaven
Bericht 3 van 5
3.440 Weergaven
Thanks for the reply!.
The MSN number is 10020310
Since posting my question, I've come across a very good deal for a GeForce GTX 1650. If this card would work in the PC, confirmation of that would be all the answer I need at this point. If not, the original question remains.
Best wishes,
C.
Gehringer
Retired
Bericht 4 van 5
3.437 Weergaven
Bericht 4 van 5
3.437 Weergaven
Hi @CeeKay71 ,
I would advise you to contact the graphic card manufacturer and check if it is compatible with your MB (ECS H81H3-EM2 SPO S1150 W8 V2#).
An alternative would be for you to buy it from a seller that would accept a refund/return in case it does not work.
Regards,
Gehringer
CeeKay71
Bericht 5 van 5
3.425 Weergaven
Bericht 5 van 5
3.425 Weergaven
Hello again,
4 ANTWOORDEN 4
