Medion i3-530
15 ANTWOORDEN 15
WalFin
Bericht 1 van 16
17.780 Weergaven
Bericht 1 van 16
17.780 Weergaven
Medion i3-530
Hi
Spec....
Motherboard MS-7616
Intel Core i3-530 (2.93Ghz 4 mb Intel Smart Cache)
Nvidia Geforce G210 Directx 10 Graphics card with 512mb
3 GB DDR3 SDRAM
1 TB S-ATA disk
Multiformat DVD/CD burner
High Speed Wireless Lan 802.11n-Standard
This desktop is quite old but still works okay. However, on trying to increase RAM to 8GB (2 x 4GB), on startup it immediately goes to "Blue Screen". When I switch off and put the original 3GB RAM back in, it starts up as normal, no Blue Screen. I have reset the BIOS and tried with only 4GB stick. No difference. Help.
15 ANTWOORDEN 15
Gehringer
Retired
Bericht 2 van 16
12.241 Weergaven
Bericht 2 van 16
12.241 Weergaven
Hi @WalFin ,
do you have the MSN number of your product?
it is an 8-digits number written in the label underneath it.
Regards,
Gehringer
WalFin
Bericht 3 van 16
12.236 Weergaven
Bericht 3 van 16
12.236 Weergaven
I presume you mean the S/N. Yes, it's on a label at the bottom of the back panel. Should I disclose this number?
WalFin
Bericht 4 van 16
12.234 Weergaven
Bericht 4 van 16
12.234 Weergaven
I also have a Art,-Nr which is 8 digits. The MED S/N is considerably more than 8 digits, though.
WalFin
Bericht 5 van 16
12.232 Weergaven
Bericht 5 van 16
12.232 Weergaven
Okay, just found out that the Art Nr is the MSN and yes it is 8 digits. Is it safe to broadcast this number on this forum?
WalFin
Bericht 6 van 16
12.211 Weergaven
Bericht 6 van 16
12.211 Weergaven
Hi
Yes I have found the MSN. What do I do now?
Bericht 7 van 16
12.208 Weergaven
Bericht 7 van 16
12.208 Weergaven
Hi @WalFin
Let us know the number so that we can check which computer you have.
bye Fishtown
WalFin
Bericht 8 van 16
12.202 Weergaven
Bericht 8 van 16
12.202 Weergaven
MSN 10013506
Bericht 9 van 16
12.197 Weergaven
Bericht 9 van 16
12.197 Weergaven
Hi @WalFin
you have:
1x 1024 MB DDR3-SDRAM (PC3-10600 / 1333 MHz)
1x 2048 MB DDR3-SDRAM (PC3-10600 / 1333 MHz)
Memory Support
  • DDRIII 1066 / 1333 Mhz (16 GB Max)
  • 4 DDRIII DIMMs (240pin / 1.5V)
  • Single /Dual channel mode
Allocation of the working memory from the service manual from MS 7616 v1.0
bye Fishtown
WalFin
Bericht 10 van 16
12.180 Weergaven
Bericht 10 van 16
12.180 Weergaven
Forgive my ignorance in these matters, please see the last RAM I purchased (see photo). Is this one compatible with my MS-7616. I have tried two other RAM cards which were returned (with exactly the same "blue screen" error). Three faulty RAMs is surely almost impossible? Not sure the jpg is showing for some reason. So the RAM is PATRIOT, PSD34G133381, PS00 1042, 4GB PC3-10600 CL9 (4GB PC3-10600 1333MHz CL9). Hope this helps?RAMRAM
15 ANTWOORDEN 15
