Medion MS-7593 Bios (x58)
9 REPLIES 9
zenof91
Message 1 of 10
Message 1 of 10
Hallo .
Ich habe einen Medion MS- 7593 Motherboard PC und ich versuchte, das BIOS mit Hilfe der Original- MSI -Website ( einen Fehler 😞 ) blinken. Bitte , kann ich mich des Medion MS- 7593 BIOS so kann ich zu erholen und stellen Motherboard Arbeit ?
Vielen Dank und entschuldigen Sie mich für mein Google Translator Deutsch.
Hello.
I have a Medion MS-7593 motherboard pc and I tried to flash bios using the original from MSI website (a mistake 😞 ). Please, can I get original Medion MS-7593 bios so I can recover and make motherboard work?
Thank you very much, and excuse me for my Google Translator German.
1 ACCEPTED SOLUTION
mic
Moderator Moderator
Message 4 of 10
Message 4 of 10
Hi,
@zenof91
here is the Link to the Bios   ->Link<-
mfg,
mic
9 REPLIES 9
mic
Moderator Moderator
Message 2 of 10
Message 2 of 10
Hi, we need the MSN of the PC or the Serial Number.
We have different revisions of this Mainboard.
mfg,
mic
zenof91
Message 3 of 10
Message 3 of 10
Ok I found the serial number:
Article no: 20045381
MS-7593B1002447543
Thank you very much!! 😉
mic
Moderator Moderator
Message 4 of 10
Message 4 of 10
Hi,
@zenof91
mfg,
mic
zenof91
Message 5 of 10
Message 5 of 10
Hello.
Thank you very much, I restored that bios using ctrl and home at start and it worked perfectly!!!
@bearbeitet vielen dank! 😉
Stevoten
Message 6 of 10
Message 6 of 10
Hello,
i have the exact same problem.
MED S/N XXXXXXXXXXXXXX
Art. NR.: 10014060
Mainboard:  MS-7593
PCB Version:  1.1
Could really use the original bios file. (was called A7593MLN.105)
Thanks in advance!
MOD-Edit:
Seriennummer entfernt.
Bitte sei so nett und beachte zukünftig die Nutzungsbedingungen.
Message 7 of 10
Message 7 of 10
Hello @Stevoten and welcome to the community.
Your PC with MSN 10014060 has the same motherboard (article number 20045381) used by user "zenof91". The BIOS should work for you, too.
Greetings - Andi
Stevoten
Message 8 of 10
Message 8 of 10
Hi @Andi ,
thanks for the fast response!
Does the Recovery work by renaming the BIOS file to AMIBOOT.ROM and putting it on a FAT formatted Usb-Stick oder burning it on a CD and then pressing STRG+HOME at startup? (Since the board has no IDE connector i don't know how eldo to do it)
Or is there another method i should use?
I wanted to be sure how to proceed with the recovery before I completely brick the BIOS..
Thanks alot for your help and sry for posting the serialnumber previously! 😉
Message 9 of 10
Message 9 of 10
Hello @Stevoten.
Unfortunately, I have no personal experience with BIOS repair. Please get in touch with user "zenof91". I'm sure he can give you some advice.
Greetings - Andi
Stevoten
Message 10 of 10
Message 10 of 10
@zenof91
Do you maybe have some advice on how to recover the bios? Since the file is 4mb (amibios8 ?) I can't go the usual floppy way..
Thanks!!
9 REPLIES 9
