23.01.2024 20:47 - bewerkt 23.01.2024 20:48
Hi all,
I've just purchased a Medion Engineer X32 and I have a few questions, I'm hoping you can help.
Firstly, the Samsung 16GB DDR5 4800MHz is only running at 4400Mhz.
I've looked in the BIOS (which seems very out dated) and can find nowhere to adjust the multipliers or enable XMP.
That brings me to the BIOS version, it's very old (760H7EMW0X.102, from 27/12/2022), where can I find an update, should one exist?
The board seems to be an ECS B760H7-EM V1.0. I've checked the ECS site and it doesn't exist. Does anyone have a link to this board? Even Google isn't too helpful here, is it a custom board for Medion?
I've checked the Medion site and there's no downloads for this machine on the support page.
And finally the RGB, how do I turn it of, or at least fix the colour?
Thanks in advance.
op 23.01.2024 22:31
op 23.01.2024 22:31
Hello and welcome
Please state your MSN number from the computer.
try this software to change the colors:
https://cdn.medion.com/downloads/software/MEDION_RGB_Light_Center.zip
bye Fishtown
op 23.01.2024 21:37
op 23.01.2024 21:37
Welcome here.
@PeterB79 schrieb:Firstly, the Samsung 16GB DDR5 4800MHz is only running at 4400Mhz.
... can find nowhere to adjust the multipliers or enable XMP.
Das ist normal with Medion PC. XMP profiles are blocked. The RAM usually runs for safety reasons about 10 % less the specs. The Board usually is a MedionOEM Board
About a new Bios you should ask a moderator, e.g. @Major_ToM , which will be informed by now.
Cheers, daddle
op 23.01.2024 21:49
op 23.01.2024 21:49
Thank you for the reply, I'll wait to see if a moderator replies in the next couple of days, if not I'll contact one of them.
I just spotted that I posted this in the wrong forum...whoops!
op 23.01.2024 22:31
op 23.01.2024 22:31
Hello and welcome
bye Fishtown
op 24.01.2024 07:37
op 24.01.2024 07:37
Hi Fishtown,
The MPN is: 10025109.
Thank you for the suggestion and link, I'll try that later today.
24.01.2024 08:43 - bewerkt 24.01.2024 08:44
Hi @PeterB79 ,
I´ll check for the information and a current BIOS version and come back ASAP
Cheers
op 24.01.2024 13:20
op 24.01.2024 16:23
29.01.2024 08:59 - bewerkt 29.01.2024 09:02
Hi @PeterB79 , @Fishtown , @daddle ,
just received a feedback from tech dept.,which sounds as: "Our ECS mainboards are (regardless of the XMP settings) permanently set to 4400Mhz."
I take this as a fact and decide not to comment on it, not being aware of the complete technical background.
Cheers
op 29.01.2024 11:06
op 29.01.2024 11:06
Thank you for finding out and getting back to me. It's not the answer I was hoping for, but your help is appreciated. I'll probably swap out the main board later down the line, for now the performance is fine.
Did they say whether there was an update to the old BIOS version?
