H81H3-EM2 VER 1.0 BIOS dump
15 ANTWOORDEN 15
Andissace
Bericht 1 van 16
16.819 Weergaven
Bericht 1 van 16
16.819 Weergaven
Hello! I bricked my board during an BIOS update (my stupidity) and I can't seem to find the BIOS anywhere. The pages seem to be deleted so I am asking nicely for someone to do a BIOS dump of that motherboard. The BIOS chip is 25L6406E (The ROM image should be 8192K), and I will be restoring the chip using a free utility called "flashrom"
The MSN number is : 10018820
The PC model is : PC MT 22 (MED MT 8092N)
Hello! I love computers that's all.
Tags (4)
15 ANTWOORDEN 15
Andissace
Bericht 11 van 16
4.814 Weergaven
Bericht 11 van 16
4.814 Weergaven
Thanks very much! Will be waiting patiently.
TPFLegionaire
Retired
Bericht 12 van 16
4.802 Weergaven
Bericht 12 van 16
4.802 Weergaven
Hi @Andissace
Thank you for your patience, I have the following info
in a nutshell:
ECS made things quite complicated with this motherboard
If you have Revision 1, you might might use Bios version V 2.15, but you have another version of the H81 motherboard then it´s possible  that there are two further option  (like V 3.x, or V 4.0x)
Unfortunately there is no indicator on the board.
Do you know which version of BIOS you had installed prior to your failed update?
If we cannot identify it further and if you try the above BIOS and it fails again, then your next option is an out of warranty quote or sourcing a working motherboard and replacing it yourself.
Let me know how you get on.
Cheers!
TPFLegionaire
MEDION AG - A Lenovo Company • • Community: community.medion.com
Please reward helpful posts with Kudos and mark solutions with Accept as solution.
Andissace
Bericht 13 van 16
4.787 Weergaven
Bericht 13 van 16
4.787 Weergaven
I don't remember the version I installed, but I can try all of the versions you listed.
There was a website where all of the BIOS were listed, but I can't seem to find it.
EDIT : The 2.15 BIOS didn't work.
Jracaiz85
Bericht 14 van 16
3.176 Weergaven
Bericht 14 van 16
3.176 Weergaven
Hola @Andissace yo intenté actualizar de la versión 304 a 309 pero no funciona bien, pero guardé una copia de la 304. Yo he intentado volver a la 304 mediante un programador externo pero lo conecté mal y creo que quemé la BIOS. Tengo que desoldar y colocar una nueva. La copia de la 304 es de 4 mb
bega82
Bericht 15 van 16
1.859 Weergaven
Bericht 15 van 16
1.859 Weergaven
Hello
i have same problem with this motherboard ver 1.0 and 215 bios dosnt work.
Is there bios dump that worjk with this mb h82h3-em2 ver 1.0
thanks
Mastermind
Bericht 16 van 16
1.755 Weergaven
Bericht 16 van 16
1.755 Weergaven
Hi @bega82 ,
are you also in possesion of the DT PC with the MSN 10018820 article number?
Cheers
15 ANTWOORDEN 15
