H81H3-EM2 VER 1.0 BIOS dump
15 ANTWORTEN 15
Andissace
Nachricht 1 von 16
16.814 Aufrufe
Nachricht 1 von 16
16.814 Aufrufe
Hello! I bricked my board during an BIOS update (my stupidity) and I can't seem to find the BIOS anywhere. The pages seem to be deleted so I am asking nicely for someone to do a BIOS dump of that motherboard. The BIOS chip is 25L6406E (The ROM image should be 8192K), and I will be restoring the chip using a free utility called "flashrom"
The MSN number is : 10018820
The PC model is : PC MT 22 (MED MT 8092N)
Hello! I love computers that's all.
Tags (4)
15 ANTWORTEN 15
Andissace
Nachricht 11 von 16
4.809 Aufrufe
Nachricht 11 von 16
4.809 Aufrufe
Thanks very much! Will be waiting patiently.
TPFLegionaire
Retired
Nachricht 12 von 16
4.797 Aufrufe
Nachricht 12 von 16
4.797 Aufrufe
Hi @Andissace
Thank you for your patience, I have the following info
in a nutshell:
ECS made things quite complicated with this motherboard
If you have Revision 1, you might might use Bios version V 2.15, but you have another version of the H81 motherboard then it´s possible  that there are two further option  (like V 3.x, or V 4.0x)
Unfortunately there is no indicator on the board.
Do you know which version of BIOS you had installed prior to your failed update?
If we cannot identify it further and if you try the above BIOS and it fails again, then your next option is an out of warranty quote or sourcing a working motherboard and replacing it yourself.
Let me know how you get on.
Cheers!
TPFLegionaire
MEDION AG - A Lenovo Company • • Community: community.medion.com
Please reward helpful posts with Kudos and mark solutions with Accept as solution.
Andissace
Nachricht 13 von 16
4.782 Aufrufe
Nachricht 13 von 16
4.782 Aufrufe
I don't remember the version I installed, but I can try all of the versions you listed.
There was a website where all of the BIOS were listed, but I can't seem to find it.
EDIT : The 2.15 BIOS didn't work.
Jracaiz85
Nachricht 14 von 16
3.171 Aufrufe
Nachricht 14 von 16
3.171 Aufrufe
Hola @Andissace yo intenté actualizar de la versión 304 a 309 pero no funciona bien, pero guardé una copia de la 304. Yo he intentado volver a la 304 mediante un programador externo pero lo conecté mal y creo que quemé la BIOS. Tengo que desoldar y colocar una nueva. La copia de la 304 es de 4 mb
bega82
Nachricht 15 von 16
1.854 Aufrufe
Nachricht 15 von 16
1.854 Aufrufe
Hello
i have same problem with this motherboard ver 1.0 and 215 bios dosnt work.
Is there bios dump that worjk with this mb h82h3-em2 ver 1.0
thanks
Mastermind
Nachricht 16 von 16
1.750 Aufrufe
Nachricht 16 von 16
1.750 Aufrufe
Hi @bega82 ,
are you also in possesion of the DT PC with the MSN 10018820 article number?
Cheers
15 ANTWORTEN 15
