Expansion USB 3 ports from motherboard
4 ANTWOORDEN 4
cuchulain
Bericht 1 van 5
3.632 Weergaven
Bericht 1 van 5
3.632 Weergaven
Good Morning. I am new to this forum and I would like to know some details about my PC.
I have a Medion i7 computer. 12 RAM.
My motherboard H67H2-EM and it has 2 USB 3.0 connections. It has no pin 20 connection.
I want to expand new USB 3.0 and in all forms of expansion it connects from pin 20 of the motherboard that I do not have. My question is:
Do the motherboard's USB ports directly read USB drives or only serve as a power source? How do I connect PCIe from USB ports included in motherboard ?.
Thanks for accepting me in the forum.
Regards
4 ANTWOORDEN 4
Gehringer
Retired
Bericht 2 van 5
3.624 Weergaven
Bericht 2 van 5
3.624 Weergaven
Hi @cuchulain and welcome to the Forum!
Can you please provide me the MSN number of your machine?
It is an 8-digits number (often starting by 300 or 500) printed in the label underneath your product.
Regards,
Gehringer
cuchulain
Bericht 3 van 5
3.608 Weergaven
Bericht 3 van 5
3.608 Weergaven
Hi. I send data from my computer. I attach a photo.
Greetings and thanks
cuchulain
Bericht 4 van 5
3.607 Weergaven
Bericht 4 van 5
3.607 Weergaven
Hi. I forward data from my computer. I think it does not support photography and I send data. MSN does not appear but I send the rest of the data.
Greetings and thanks.
Model: PC MT 14
Typ: MED MT717
P/N: 20050192
S/N: OE 0015021
Ar-nº: 10015577
Gehringer
Retired
Bericht 5 van 5
3.539 Weergaven
Bericht 5 van 5
3.539 Weergaven
Hi @cuchulain ,
I think the best solution for you would be to have a USB 3 PCI-E 2.0 1x card.
Even though we can't recommend any third-party products, you should be looking for a product similar to the one on this link here.
To be safe, buy it from a seller that would accept returns and refunds.
Regards,
Gehringer
4 ANTWOORDEN 4
