19.12.2024 19:08 - edited 19.12.2024 19:36
Sorry Erazer i5 10400 3060TI
Tried twice to upgrade RAM, first issue was restricted space due to CPU fan and second issue was Crucial DDR4 pro 32GB 3200 doesn't work. Does anyone have a suggestion of what actually will work please?
This was bought from Aldi in Nov 2021.
B560 motherboard with two RAM slots.
20.12.2024 12:37
20.12.2024 12:37
Hi. Nobody can help you if you do not specify first the Medion PC with name and MSN number, and second the RAM modul more exactly. Providing a link to the retailer selling the Crucial RAM would be helpful too.
Cheers, daddle
21.12.2024 19:00
21.12.2024 19:00
System MD 34625
B560 H6-EM2
RAM crucial pro CP18g4dfra33a. 16gb DDR4 3200
Is there any RAM that will work for 2x16GB and at 3200?
21.12.2024 19:43
21.12.2024 19:43
@MarcNSmith schrieb:System MD 34625
B560 H6-EM2
You can not use in this mainboard XMP memory modules. They will fall back at 2400 MHz.
Check on the modules which came with the system for their specs. They should have a sticker or imprint telling you. But you can not enhance the speed you would like to.
Because there is an IT dropdown on the Medion database, I can not tell you exactly about the built in RAM. But you could try 2x 16 GB modules,
Special: We do not give tips for any brand.
Cheers, daddle
