27.09.2021 17:24
27.09.2021
17:28
- last edited on
26.10.2021
16:32
by
Rex
27.09.2021
17:28
- last edited on
26.10.2021
16:32
by
Rex
(Hi, if you post in a geman forum you should write in german.)* Second you should name your Computer model, together with the 8-digit MSN number, which you'll find on a sticker on the back or the bottom of your PC.
Otherwise we cannot help you.
Cheers, daddle
Admin Edit:
This thread has meanwhile been moved to the English language section!
29.09.2021 12:57
29.09.2021 12:57
Hello @eduelias ,
if you cannot find any XMP settings in the BIOS/UEFI most likely there is no option for that. It is not really surprising to me with an Medion computer. If your memory works with standard defaults it is what I expect. Otherwise go back to your previous memory configuration.
Yours sincerely Jan
04.10.2021 09:41
04.10.2021 09:41
Hi!
First of all, I am so sorry, didn't see that this is a German forum and I don't speak German.
Second, thanks for your time and here it's my MSN: 1D093010020163, Erazer X87047.
My picture of the label is almost unreadable, as the computer stays in a quite hard-access place and on 100% of the time.
I have two questions:
1) Is it possible to turn on the XMP with the current memory banks I have?
2) Can you provide me a link to buy compatible memories?
Thanks in advance for all your help and, again, Sorry about the English,
Edu.
04.10.2021 13:40 - edited 04.10.2021 13:54
Hello @eduelias
Unfortunately your info gives not the MSN. The MSN ist a 8-digit number code. Spezification for an Erazer X87047 you can find here (->Technische Spezifikationen). If it is your computer model, the MSN 10023248 is on the label or you can check with Win+r -> msinfo32. The last 8 digits next to 'System-SKU' is the MSN.
@eduelias wrote:I have two questions:
If the specs of the link apply to your computer the memory data are :
2x 8192 MB DDR4-SDRAM (PC4-21300 / 2666 MHz)Dual Channel Memory (2/2 Slots covered; 32 GB max.)
Memory is compatible if it fullfills these data.
More information about the build-in memory you can find if the vendor is known. This information can be found with the help of tools like hwinfo (freeware). But I'm skeptical. Why should Medion use superior memory components, if there is no possibility to activate the XMP-option ? A thread which describes a misalignment of the memory frequency gives the information for the mainboard b360h4-em (message 2): only standard defaults are possible - no manual settings.
Yours sincerely Jan
more info about MEDION Erazer X87047 : https://www.vergelijkdesktops.nl/desktop/medion/medion-erazer-x87047
04.10.2021 15:05
04.10.2021 15:05
Hello @eduelias
The probability of activating an XMP profile in a Medion BIOS tends towards zero.
The Aptio Bios used in the PC is correspondingly limited.
Greetings
04.10.2021 17:29
04.10.2021 17:29
Hi,
Yes, yes, the MSN is 10023248 (WIN+R for the win!).
Thanks for the clear information! Together with the PC I bought this (https://www.amazon.de/gp/product/B07GTG2T7L/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1) 2x16GB DDR4 3200Mhz banks and they're running at 2133Mhz only. I heard that enabling the XMP would make them run at 3200Mhz but it seems that this motherboard is not made for such frequencies, right?
I never ran the stock ones so I wouldn't know if they were running with a higher frequency or not.
Thanks for your time and clear answers! Have a wonderful day! 😄
