The problem of saving the found stations
2 ANTWOORDEN 2
Ljubo
Bericht 1 van 3
2.719 Weergaven
Bericht 1 van 3
2.719 Weergaven
Ljubo
Nachricht 1 von 1
I bought the radio set Medion DAB+ P66550.
Everything works perfectly fine, except when I try to save the found stations.
The process I followed: I manually found the stations (the signal was good), then clicked the PRE / MEM button, found an empty spot with the TUN-/TUN+ buttons and confirmed the spot with >II. According to the instructions, the station should be saved this way, but it was not and the screen said Preset Empty.
Both, DAB and FM processes have the same result.
Thank you for you help.
Kind Regards,
Ljubo
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
TPFLegionaire
Retired
Bericht 2 van 3
2.711 Weergaven
Bericht 2 van 3
2.711 Weergaven
@Ljubo
Welcome to the forum
Sorry to hear about the issues you are having with the radio, just to make sure I am posting the instructions below, could you double check that you are following all the steps. Let me know if you need more assistance.
Cheers!
TPFLegionaire
MEDION AG - A Lenovo Company • • Community: community.medion.com
Please reward helpful posts with Kudos and mark solutions with Accept as solution.
2 ANTWOORDEN 2
TPFLegionaire
Retired
Bericht 2 van 3
2.712 Weergaven
Bericht 2 van 3
2.712 Weergaven
@Ljubo
Cheers!
TPFLegionaire
Ljubo
Bericht 3 van 3
2.705 Weergaven
Bericht 3 van 3
2.705 Weergaven
Solved.
Thank you
2 ANTWOORDEN 2
