TV MD31204 Audio output choise ?
2 REPLIES 2
OutputOnTV
Message 1 of 3
Message 1 of 3
Hello,
I have bought a Medion MD31204 TV and I was wondering how I could change the audio settings to outup to S/PDIF. De settings in MENU seem limited:
Sound:
  • Sound Mode: Standard, music, movie, user
  • Balance
  • Auto Volume
  • Surround Sound
  • Digital Audio Output: PCM of AUTO
Furthermore I cannot select the other settings under Sound.
MENU->Settings seems to have no relevant sound options to me.
Please Help.
Thanks in advance!
1 ACCEPTED SOLUTION
OutputOnTV
Message 3 of 3
Message 3 of 3
Hello Daniel,
After further testing I came to the conclusing it is working. Thanks.
Digital audio output AUTO and by that the sound is playing on the TV itself and on the external speakers aswell.
I turned down the volume of the TV to 0 and now everything is working perfect.
Kind regards.
2 REPLIES 2
Daniel
Message 2 of 3
Message 2 of 3
Hello @OutputOnTV ,
Normally it should be sufficient to set the digital audio output to AUTO.
Can you see that light is shining out of the SPDIF connector?
VG,
Daniel
OutputOnTV
Message 3 of 3
Message 3 of 3
Hello Daniel,
Kind regards.
2 REPLIES 2
