20.06.2019 17:09
20.06.2019 17:09
Hello!
The subwoofer of my laptop is not working, I tried everything, but It doesn't produce any sound. I test it playing music and the realtek audio manager, nothing works.
25.06.2019 10:04
25.06.2019 10:04
Hi @mtysaka ,
The Realtek audio manager usually shows a picture of a setup with all available speakers, is it set to 2.1 audio, and is the subwoofer listed there? I think you can also test the speakers individually there.
You could also try and update the drivers and see if it makes a difference, and if all else fails, you could always do a factory restore to exclude any other software issues.
25.06.2019 10:04
25.06.2019 10:04
Hi @mtysaka ,
16.04.2020 16:48
16.04.2020 16:48
Hello! Actually I have faced with the same problem wth my audio manager, but I didn't have time to find the answer becasue all my time was taken by writing essays, with the help of this page https://akadem-ghostwriter.de/ but i am really happy to find the answer in this thread!
15.07.2020 12:09
15.07.2020 12:09
Hi,
I've been trying to install the package in all different variations:
1. Only Realtek
2. Only SBX.
3. Both but Realtek first
4. Both but SBX first.
No solution. The subwoofer is not visible in both apps. Realtek has got options of: Stereo, Quadrophonic, and 5.1 (the same as SBX) but setting those won't let any playback from the sub.
the first two - nothing that can be assigned to the sub, 5.1 - there is a sub visible, but actually the sound goes from the main speakers. I even try to change center/sub - without any solution. I don't know what to do to enable the sub.
