Medion Erazer Control Center
8 RÉPONSES 8
Seagrey
Message 1 sur 9
29 617 Visites
Message 1 sur 9
29 617 Visites
Hello,
I own a MEDION ERAZER X7853 (MD 60540) UK  MSN: 30022549 and I am unable to find on the support portal an updated version of the Control Center software.
Recentnly I have formatted my laptop and reintalled Windows 10 and I need to reinstall the Control Center.
I wrote to the support some time ago but they have not provided me with an answer regarding this matter yet.
Please, can you help?
Thanks in advance!
No downloads!No downloads!
Balises (2)
8 RÉPONSES 8
Fox10
Message 2 sur 9
29 606 Visites
Message 2 sur 9
29 606 Visites
Hi @Seagrey
please check the recovery partition. Maybe under the Folder "Drivers" you will finde Erazer Control Center.
best regards Fox10
#Medion #Erazer #läuftbeimir
Seagrey
Message 3 sur 9
29 603 Visites
Message 3 sur 9
29 603 Visites
@Fox10wrote:
Hi @Seagrey
best regards Fox10
Hello @Fox10,
I have formatted my laptop thus I don't have recovery partition.
So, where can I download the Control Center software??
Message 4 sur 9
29 591 Visites
Message 4 sur 9
29 591 Visites
@Seagrey
Quite stupid to delete those folders without a backup of the folder Drivers, Tools and Recover.
The Software, you normally don't get from Medion, and the Drivers are usually to be downloaded on the Medion service-page.
But you could ask a Moderator, maybe @Luke or @Rex, if they could send you a copy; possibly you will have to pay for it.
regards, daddle
ertinio
Message 5 sur 9
27 523 Visites
Message 5 sur 9
27 523 Visites
Mate you will not be able to install the control center as you have to update bios. i have the same exact laptop x7853 and have had no luck finding the bios update
Mastermind
Message 6 sur 9
27 508 Visites
Message 6 sur 9
27 508 Visites
Hi @ertinio ,
can you please inform us, which BIOS version you currently installed on your MEDIOnERAZER X7853 notebook?
Cheers
ertinio
Message 7 sur 9
27 496 Visites
Message 7 sur 9
27 496 Visites
HI , when I installed the fresh windows pro it downgradeD the bios to 1.05.03RGME1_0006 04/02/17 AND THEREFORE UNABLE TO INSTALL the control center saying erazer does not support this platform everytime i start it. The weird part is that I can' find the update anywhere not even on the medion website mate. Could you please help with a link as i cant turn on the discreet option therefore can't play serious games.
ice-JAck
Message 8 sur 9
25 725 Visites
Message 8 sur 9
25 725 Visites
Wich one do i need te reinstall ?
Gehringer
Retired
Message 9 sur 9
25 695 Visites
Message 9 sur 9
25 695 Visites
Hi @ice-JAck ,
go to the Medion service website and check if there is a BIOS update listed at the downloads area.
Regards,
Felipe
8 RÉPONSES 8
