on 16.12.2024 18:03
on 16.12.2024 18:03
Hello. I have a problem with my Medion Erazer Deputy P10 laptop. Windows 11 24H2 is installed, none of the HotKey versions are working. I can control the speed of the fans through a keyboard shortcut. But I can't change the color of the keyboard backlight. Does anyone have a solution to this problem?
on 16.12.2024 19:01
on 16.12.2024 19:01
Hello @Entony ,
have you tried reinstalling the hotkey drivers?
https://www1.medion.de/downloads/index.pl?op=detail&id=21221&type=software&lang=uk
bye Fishtown
on 16.12.2024 19:31
on 16.12.2024 19:31
Yes, I reinstalled it. When clicking on special characters like Fn+1 or TAB, the application icon is displayed on top. But the GameCenter application, even if opened, does not start, although I see that it is running.
Let me clarify that I installed the drivers on a clean system, which I previously reset to factory settings.
