Action Cam
1 REPLY 1
Vicky
Message 1 of 2
Message 1 of 2
Action Cam
I'm looking for a action cam I can attach to my head for when I go on my extreme walks through the local woods.
Can you recommend one ?
1 ACCEPTED SOLUTION
Bodgekin
Message 2 of 2
Message 2 of 2
Hi Vicky,
Considering this is a Medion community, have a look at: http://www.medion.com/gb/shop/searchProduct?searchTerm=actioncam
One of my mates has this webcam and the headband (they are compatible, despite what the description says), and the footage is pretty good. Not comparable to something like a GoPro hero 4, but its also alot cheaper.
Price-quality is pretty good, but ultimately it will depend on what your goal is. If you want the highest quality footage, then you'd have to look into the more expensive actioncams, if you want to make some fun movies for yourself in reasonably good quality, then I think you cant go wrong with the Medion.
Kind regards,
Bart
1 REPLY 1
Bodgekin
Message 2 of 2
Message 2 of 2
Hi Vicky,
Kind regards,
Bart
1 REPLY 1
