Medion Akoya S6213 Battery Shutting off at 2%
2 REPLIES 2
James
Message 1 of 3
Message 1 of 3
Hi
My friend has a problem where thier computer keeps turning off when the battery reaches 2% even when the power settings have been changed to never sleep or hibernate. Has anyone else had this problem and is there a fix for this?
Many Thanks
James
1 ACCEPTED SOLUTION
Message 2 of 3
Message 2 of 3
Hi @James..
This is not a bug but a feature!
Keeps the Battery longer alive.
Die you install the new Bios? for the 6213?
Link:  http://community.medion.com/t5/Notebook-Netbook/Bios-Updates-f%C3%BCr-MEDION-AKOYA-S6213-14-amp-S641...
Regards, daddle
2 REPLIES 2
Message 2 of 3
Message 2 of 3
Hi @James..
Regards, daddle
James
Message 3 of 3
Message 3 of 3
Hi @daddle
Thank you for this, I have let my friend know about the BIOS update.
Thanks
James
2 REPLIES 2
