Akoya E6239 input jack cable
2 REPLIES 2
Tewstrose
Message 1 of 3
Message 1 of 3
Hiya,
A few days ago I noticed my laptop wasn't charging very well, so I gave it the once over and found that the cable (kinda like this only not) that runs from the motherboard to the power socket had snapped away from it's solder, any clues as to what part I need to replace it?
Many Thanks
Tewstrose
1 ACCEPTED SOLUTION
Bodgekin
Message 2 of 3
Message 2 of 3
Hi @Tewstrose
You can find parts for a E6239 (I'm not sure if this is the exact version of the E6239 you have, but I'd suspect they all have the same cable) through this link.
My guess is you need:
MSN: 40047012
Cable, Powerboard cable, internal
But perhaps you could contact Medion directly to verify this just to be absolutely sure.
Kind regards,
Bart
2 REPLIES 2
Bodgekin
Message 2 of 3
Message 2 of 3
Hi @Tewstrose
MSN: 40047012
Kind regards,
Bart
Tatütata-Tattoo
Explorer
Message 3 of 3
Message 3 of 3
Good explaination, thanks!
Smiley LOL
2 REPLIES 2
