Read-only memory (ROM)
Read-only memory (ROM) is a type of non-volatile memory used in computers and other electronic devices. Data stored in ROM can only be modified slowly, with difficulty, or not at all, so it is mainly used to store firmware (software that is closely tied to specific hardware, and unlikely to need frequent updates) or application software in plug-in cartridges.
Strictly, read-only memory refers to memory that is hard-wired, such as diode matrix and the later mask ROM (MROM), which cannot be changed after manufacture. Although discrete circuits can be altered in principle, integrated circuits (ICs) cannot, and are useless if the data is bad or requires an update. That such memory can never be changed is a disadvantage in many applications, as bugs and security issues cannot be fixed, and new features cannot be added.
More recently, ROM has come to include memory that is read-only in normal operation, but can still be reprogrammed in some way. Erasable programmable read-only memory (EPROM) and electrically erasable programmable read-only memory (EEPROM) can be erased and re-programmed, but usually this can only be done at relatively slow speeds, may require special equipment to achieve, and is typically only possible a certain number of times.
Version History
Revision #
2 of 2
Last update:
‎14.02.2018 12:26
Updated by:
Labels (1)
