Interface (computing)
In computing, an interface is a shared boundary across which two or more separate components of a computer system exchange information. The exchange can be between software, computer hardware, peripheral devices, humans and combinations of these. Some computer hardware devices, such as a touchscreen, can both send and receive data through the interface, while others such as a mouse or microphone may only provide an interface to send data to a given system.
  • Hardware interfaces
    Hardware interfaces exist in many of the components, such as the various buses, storage devices, other I/O devices, etc. A hardware interface is described by the mechanical, electrical and logical signals at the interface and the protocol for sequencing them (sometimes called signaling).
    A standard interface, such as SCSI, decouples the design and introduction of computing hardware, such as I/O devices, from the design and introduction of other components of a computing system, thereby allowing users and manufacturers great flexibility in the implementation of computing systems.
    Hardware interfaces can be parallel with several electrical connections carrying parts of the data simultaneously, or serial where data is sent one bit at a time.
  • Software Interfaces
    A software interface may refer to a wide range of different types of interface at different "levels": an operating system may interface with pieces of hardware. Applications or programs running on the operating system may need to interact via streams, and in object oriented programs, objects within an application may need to interact via methods.
  • User interfaces
    A user interface is a point of interaction between a computer and humans; it includes any number of modalities of interaction (such as graphics, sound, position, movement, etc.) where data is transferred between the user and the computer system.
Version History
Revision #
1 of 1
Last update:
‎14.08.2017 08:20
Updated by:
Community Manager
Labels (1)
