41370members
979online
145066posts
When I turn on my device, the fuse trips, what can I do?
To narrow down the error, you can try the following:
First, attach your device to a different power outlet and see if this results in the fuse tripping.
If you are not getting the same problem on the other power outlet then it would appear the fault is with the power outlet and not the device.
Review Date: 2021-10-17
