P5018 D wont boot
1 REPLY 1
Kev
Message 1 of 2
Message 1 of 2
P5018 D wont boot
Hey guys,
After upgrading the Ram in my P5018 D the unit will not boot, i've installed 16GB of ram, is this more then the mainboard can support or what could be the cause?
Grz. Kevin
1 ACCEPTED SOLUTION
Murphy
Retired
Message 2 of 2
Message 2 of 2
@Kev - Good morning and welcome to the Community!
The Mainboard of your PC supports a maximum of 16 GB DDR3-SDRAM (PC3-12800 / 1600 MHz) Single Channel Memory.
If you use memory modules with these specifications there should be no problem.
VG,
Murphy
1 REPLY 1
Murphy
Retired
Message 2 of 2
Message 2 of 2
VG,
Murphy
1 REPLY 1
