Medion MS-7593 Bios (x58)
3 REPLIES 3
FilleMang
Message 1 of 4
Message 1 of 4
Hello!
I just flashed my MS-7593 Medion motherboard with a MSI BIOS, now I can't get passed the memory check.
Where can I find the correct BIOS file for this motherboard?
MB: 20045381
3 REPLIES 3
Bodgekin
Message 2 of 4
Message 2 of 4
Hi @FilleMang
As far as I can see Medion has no update available for this motherboard. Perhaps you can contact Medion directly and see if they perhaps can provide you with the original version of the BIOS, but normally you'd need a system that boots to be able to install the update :(.
Kind regards,
Bart
FilleMang
Message 3 of 4
Message 3 of 4
 Thanks for your reply @Bodgekin
If I can't use the motherboards recovery feature to complete the flash (I can force the motherboard to jump into BIOS recovery), I will just have to reprogram the BIOS chip.
As I understand it people here can have a connection to Medion, for example @mic
Or maybe someone else owns one of these boards and can make a BIOS dump.
Stevoten
Message 4 of 4
Message 4 of 4
i have the exact same problem.
MED S/N 17461030020007
Art. NR.: 10014060
Could really use the original bios file. (was called A7593MLN.105)
Am stuck on POST screen after trying to update to MSI BIOS.
Would appreciate any help.
Thanks in advance!
3 REPLIES 3
