Medion Akoya P5320D
Highlighted
Message 1 of 5
Message 1 of 5
Medion Akoya P5320D
hello i have several BSOD  on win 10  !  comp several times just turn off and restart
where can i get bios update ? or what is the solution
tnx
1 ACCEPTED SOLUTION
Message 5 of 5
Message 5 of 5
Re: Medion Akoya P5320D
I fix BSOD with ccleaner professional for register cleaning,and select  No paging file (virtual memory)
Wifi adapter was disconnected from mother board i connect cable again and now it works !
Message 2 of 5
Message 2 of 5
Hi @ivanko
There are many different kinds of BSOD's with many different causes, could you give us some more info? what error message does the BSOD display? And when do you get the BSOD or the reboots, totally random or when running specific programs etc?
Kind regards,
Bart
Message 3 of 5
Message 3 of 5
KMODE_EXCEPTION_NOT_HANDLED
and
"STOP 0×00000050: PAGE_FAULT_IN_NONPAGED_AREA – win32kfull.sys"
Computer starts fine then BSOD a few minutes later,but not every time.
I use these programs  memtest86,chkdsk,verifier,sfc,ccleaner,windows diagnostic tools and there was no errors
any idea?
it is possible to bios update on this comp?
Message 4 of 5
Message 4 of 5
and how to enter bios ? i can choose only f8 for boot menu
also i need a wifi driver for win 10,because when install win 10 driver disappeared and old driver doesn¨t work in win 10
tnx for all
best regards
Message 5 of 5
Message 5 of 5
