AKOYA P5107 D sleep issue
1 REPLY 1
Peteee
Message 1 of 2
Message 1 of 2
Hi,
My Akoya does not wake from sleep, I have restored the computer to factory settings but after updates it will not wake from sleep again.
1 REPLY 1
Bodgekin
Message 2 of 2
Message 2 of 2
Hi Peteee,
Which Windows version do you have installed on your system? Windows 8 or 10? If its still Windows 8, you could try to turn off automatic updates and install updates manually one by one to try and find the culprit.
In Windows 10 I dont think its possible to turn off updates, so the only way test if its an update from Windows I can think of is to test the system without any internet connection.
Kind regards,
Bart
1 REPLY 1
