DECT set, 2nd handset
1 REPLY 1
Idiocrazy
Message 1 of 2
Message 1 of 2
On my DECT set Life S63012 I cant seem to get the second handset to work anymore. I remember it worked when I first got the set years ago, now I need it again, but the display only says "register". When I try to register it, it doesnt seem to find the main unit, the main handset works without any issues.
Any bright ideas?
1 REPLY 1
Bodgekin
Message 2 of 2
Message 2 of 2
Hi @Idiocrazy
When you try to register it, did you first push the "page" button on the main unit?  See page 47 in this manual
I remember running into similar problems with my DECT set (not Medion though) because I forgot to push a button on the base unit.
Kind regards,
Bart
1 REPLY 1
