medion akoya S15449 which has a very low sound volume
4 REPLIES 4
aferri13
Message 1 of 5
Message 1 of 5
I have a medion akoya S15449 laptop with a fully updated Windows 11 operating system which has a very low sound volume. Is there any solution for this problem?
Thank you
1 ACCEPTED SOLUTION
aferri13
Message 5 of 5
Message 5 of 5
I have applied the suggested solution and the situation has improved a bit
4 REPLIES 4
EastClintwood
Message 2 of 5
Message 2 of 5
Hello @aferri13,
Please send us your 8 digit MSN probably the problem can be solved by new drivers.
Greetings,
EastClintwood
aferri13
Message 3 of 5
Message 3 of 5
EastClintwood
Message 4 of 5
Message 4 of 5
Hallo @aferri13,
Please reinstall the drivers, which can be downloaded from the following link:
MEDION Service
If the problem persists despite the reinstallation, please contact us again.
Regards,
EastClintwood
aferri13
Message 5 of 5
Message 5 of 5
4 REPLIES 4
