Drivers for notebooks with Linux
4 REPLIES 4
MikolaOla
Message 1 of 5
Message 1 of 5
2017-07-07
Dear MEDION Service Community,
Medion Poland (Medion Polska) informed that to some notebooks,               for example:
  1. MEDION Akoya 96350. Model: WIM 2140, Product Version: 20, Firmware Version: V1.0K
  1. MEDION MD 96640, Model: WIM 2180 (MSN: 30008014).
there are no drivers for operating system Linux.
Holders of these notebooks, who are using Linux they can not start some internal devices, for example, internal microphone.
We were advised to pass this issue to MEDION Service Community by Medion Poland.
At the same time, somebody suggested to ask the programmers of the Advanced Linux Sound Architecture (ALSA) project about the creation of audio device drivers to these notebooks with Linux.
In this connection, I have a question for you:
1) Will MEDION be able to start actions in the direction of the creation drivers to these notebooks with Linux?
And if this is not possible, next question:
2) Will MEDION be able to share the necessary information to write these drivers for ASLA?
I and community from Ubuntu.pl look forward to hearing from you.
Mikołaj Łopatko
mlopatko@op.pl
4 REPLIES 4
DarkKnight
Message 2 of 5
Message 2 of 5
Hi @MikolaOla
Welcome to the community.
Drivers for the Medion product range are based on the operating system supplied with the unit at point of sale.
If you require details of chipsets and motherboard specifics, then if you contact Medion, they should be able supply that information to assist in driver development.
Hope this helps
@DarkKnight
Luke
Community Manager
Message 3 of 5
Message 3 of 5
Hello @MikolaOla,
the soundcard used in both of your notebooks is:
Realtek AL C888 Azalia 5.1 HDA (onboard)
Feel free to get back to us if you should need more info
on other internal components.
Cheers,
Luke
Anonymous
None
Message 4 of 5
Message 4 of 5
Hello @MikolaOla
have you tried with Linux driver (3.0) for ALC888?
You can find it at the end of this page:
http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownType...
greets
rob
Zwanghaft69
Message 5 of 5
Message 5 of 5
Hi,i have the Same Problem my Medion Akoya Modell ist"E7420",i need drivers for the Touchpad in Linux distribution
Called "mageia"
4 REPLIES 4
